Log on to the Software
  • The first time you connect to the switch, you must log on to CLI using the direct console port.
After you first connect to CLI you can log on to the software using the default user name and password. For more information about the default user names and passwords, see Default User Names and Passwords for CLI.
  1. At the login prompt, enter the user name.
  2. At the password prompt, enter the password.
